Haven’t got pics of it lit up at night yet. And it is wired the the spare accessory switch nearest to the steering column. This is with the existing factory wiring setup.
Per the other topic I posted in I had to modify the Loki-2 to fit like this. https://uploads.tapatalk-cdn.com/201...a16cfb4b6d.jpghttps://uploads.tapatalk-cdn.com/201...b3e145b2ae.jpg
Just about every drain plug light out there worth a damn, is too big for our newer Moombas as the drain plug is too close to the wake plate. So this one works but you have to bevel the bottom edge to clear the hinge.
It’s ok. There are other versions with larger LED arrays that would put out more lumens, which I would recommend if your budget allows.
The Loki looks cool at night, but it’s not going to be cranking out tons of light, and it’s purely due to the size of the arrays.
I would look at the Titan-2 instead if you are really looking for wow factor, and can fit it.
https://boatpluglight.myshopify.com/...-16-000-lumens
Otherwise, quality wise, I have no issues with this light.
