My boat was a dealer demo. Wonder if they upgraded the pumps? Probably a dumb question but how or where would I check to see the actual pump?
They should be behind rear panel in the bag lockers , I have two starboard and on the port side, intro see what you come up with , because actually filling 1100s in 4 minutes is pretty sweet
I can't believe you are filling 1100's in 4 minutes with the standard reversible pumps. Mine take 10 minutes. Center tank and bow bag is 15 minutes.
Found the pump information. It is a Jabsco 18670-6127. I can't seem to find the exact model numbers online.
Not sure if that what would come normally or not?
Found this on the Jabsco site.
http://www.xylemflowcontrol.com/mari...r-puppy-us.htm
18670 Commercial Duty Water Puppy (US) Bronze DC Pump
Flow rate: 8 USgallons/min (30.4 Litres/min)
Self-priming from dry up to 1.2m (4ft)
Model No.: 18670-Series
•Small bilge debris present no problem to these bronze bodied, flexible impeller pumps.
•Simple design means fewer wearing parts.
•ISO 8846 MARINE (Ignition protection).
•ISO 8849 MARINE (Bilge pump standard).
-VS- this sold by Wakemakers.
http://www.xylemflowcontrol.com/mari...ze-dc-pump.htm
Ballast King Bronze DC Pump
Wakeboard and Ski boat Ballast Pump
Flow rate: 15 USgallons/min (57 Litres/min)
Model No.: 22610 Series
•Adds approx 125lbs (56kgs) of ballast per minute
•Reversible to both fill and empty tanks
Should be the standard pump then , if you are filling them full that quick that is awesome, might want to see a pic of your bags when their full
Will do. I'll try to video it too. Maybe I'm missing something obvious.
Might be worth measuring the dimensions to make sure you actually have 1100s. Maybe your dealer told you they were but actually gave you 750s? If not, I definitely want to know your secret.
