In a car the first check would be for dirty battery cables, check battery voltage, then check voltage at solenoid. Will it crank over if you tap the solenoid with a screwdriver?
Long story short...pulled boat out of water...dealer had replaced starter over winter. Turned out to be a faulty starter. New starter, turned over several times on Saturday.
Thanks for all the input.
Sent from my SM-G950U using Tapatalk
Glad your back on the water again, Enjoy
