Bimini torn from aviator tower
Quote:
Originally Posted by
moombaman16
The reason I ask is mine did the same thing and they would not cover it because I didn't have the straps on.
I dont know how this will be viewed, I may get hung up on it. My first thought was to just try and retap it and fix myself until I got looking at it closer and saw all the mounting brackets were stripped out from the posts pulling out and the main Cross bar was really really bent (as in needing a replacement). I'll definitely be fighting it. When I bought the boat both salesmen told me I was fine putting the straps to the handles because they "weren't really needed anyways" . Clearly they were
mmandley
Just remember, 25 boat speed into a head wind of 15= 40mph wind.
I get that. I had the same thought but it's also out of my control. What's gonna suck is if I have to drive it the 2 hours to the dealer only to find that I'm told I'm out of luck for something that was not at all my fault. To top it off the boat also randomly killed out twice while towing yesterday as well as the auto surf tabs are not always engaging all the way and I'll have to cut out in the flats when I get up so the drivers can switch to middle then back to my side to get them fully engaged. This is about every 4th or 5th set now. It's growing more common as I'm growing more annoyed.
jtatexc
I've been having the same problem with my surf tabs since late June. Sounds like quite a few of us having that issue.
mattsask
And what is weird it it will screw up during a ride after a fall. I'll be riding and all is well, go down, and on next pull wave has no push so I'll have to arch out and let the driver reset it. Pretty annoying
