Originally Posted by
MLA
I believe the OEM amp is the Wet Sounds HTX-6. It has a potential of 300W rms for a woofer bridged on 2 chnls. Is this under powered? No. Can the woofer handle more wattage and benefit from it? Yes.
When someone says the output is poor and woofer barely moves, the last thing on my mind is to place an enclosure behind it. With a free-air woofer, im thinking the opposite! 2nd to last, is changing woofers. 1st on my list is making sure that whats there, is working to its optimal levels. i know how that woofer will perform on that amp, and barely moving is not it. Something else is off.
Now, one drawback to that Fusion head unit, is that the woofer zone is tied to the main zone. Meaning that if you turn zone-1 up/down, the woofer goes with it. You can only turn the woofer up to the level of zone-1. Dont confuse level with volume. Im not saying the woofer will play as loud as the in-boats. Level means head unit level, not volume. The next downside, is the head unit default settings on the woofer chnl. Most do not know there are settings, and these will impact the woofer.
