If you had the pump I'm sure it would't take more than a minute or two longer being cold.
I just might have to try that. I did not like spending the $350.00 for the oil change.
I was told you heat up the oil for two reasons. One is for it to come out. The other is so it sudspends any particals in the oil so they get sucked out when you suck out the oil.
Tazz, Changing the oil is easy. It is harder to change the oil in my car then the boat. The oil filter is easy to get too unlike my car.
Thanx Will I need to run the motor for a while to get the oil thinner?
Running it would be easiest. Another way is to buy a Block heater. Same you see on trucks up north. This is a plug in unit and heats the oil pan up for you. It allows you to start your engine in very cold weather. Basically heats the oil up.
As for the particles in the oil, if you have particles that are that big they are sinking to the bottom of the pan you have a much bigger problem.
Oil is designed to capture impurities in the engine as in dirt. It doesn't allow them to sit in the bottom of the pan and collect like sludge.
Sludge is formed by extraem amounts of foreign material getting into the oil and from just oil abuse, like not changing it and the oil goes bad, Sludge is the stuff oil collects and removes when you change it. This is why sludge is from over heating oil and it breaking down.
Your oil filter should be collecting all this crap in the oil. That's why its there. If you realy want to extend the life of your oil change the filter more often. Black oil coming out of your engine is the result of the dirt it is picking up and the abuse from heating it when the engine is running. If you change your oil and its still a nice golden brown, eighter it isnt doing its job, or you are a very lucky person to have such a clean system.
Block heater.
http://www.jcwhitney.com/jcwhitney/c...FRcjawodWl8eoA
Where can you find the drill pump itself?
Your first picture showing the couple, is there any way you can show a close up picture of that? I don't quite get what part that is.
Thanks,
Garn
