Just remember looks can be deceiving. I tested some of my setups and they looked great but totally lacked push (this was w/o the gate, but the same principal applies).
Tested my ghetto gate both straight with the hull and angled at about 20 degrees.
Results were better with the straight extended hull version.
Weight. 1180 basement
520 bow
1250 surf side
750 starboard
Two 185 lb men
No real lean
Straight gate
http://i258.photobucket.com/albums/h...pspclaie0c.mp4
Gate angle about 20 degrees
http://i258.photobucket.com/albums/h...psnx717cpv.mp4
Feel dumb for asking, but are you guys mounting these on the opposite side your surfing?
The wave was good with the angled gate but it was a bit sloppy and lacked push. We tired adding and dropping off side weight with this setup and it didn't make much of a diff.
Adjusted to straight and it cleaned right up. Wave had great push from 3' back to the curl. XLV throws a sick wave with the gate on it and nearly zero list. If you have xlv and surf you need the gate.
plus I use 1/2 cutting boards from sams club
