What's the sub setup on the 24s?
They also have a built in wash down to clean up the floor etc.
I have a heated wash down in my Mastercraft and it works great. It actually extends our short season, filling our wetsuit with the warm water, by a couple of weeks. It also is nice when having to put on a cold wet vest! My MC is a raw water cooling system so it works great. I looked into adding one for the Moomba but didn’t do it as I was told that the closed cooling system that it employs doesn’t heat the water much.
It pumps it directly from the lake into a coiled hose with a nozzle on it
Detachable hose comes with it and it connects inside the cockpit. I imagine the setup is similar to a ballast pump, where the is a thru hull fitting in the bottom of the boat and a pump that draws the water in. I should have looked under the boat while I was there lol. I’m sure Drew or one of the other factory guys can chime in with specifics.
