Under the midships seats. Here is a vid that explains it:
https://www.youtube.com/watch?v=STAF...l=HaydenBreeze
This is PERFECT thanks so much! Now I'm thinking about doing the under seats and just have a valve to decide. When loaded and everyones crap is in there can leave valve shut. When going out empty can fill it up.
So what is your total ballast weight?
2x 1800 rears
1x 1200 factory bow
2x under midship seat bags #200?
2x fill and play bags you throw in the bow? #250?
Midships are 2x 400 lbs according to wakemakers and the bow bags I estimate are around 2x 150 lbs. I should be at 6500 lbs with driver and 11.3k lbs total with boat weight.
Finally was able to get out and film some wave action. I'm 165 lbs and board is 4.6. (This is footage from before alternator failed.)
https://www.youtube.com/watch?v=aX8WQy6qUNc
https://www.youtube.com/watch?v=22OoUGhv4ZY
Looks awesome Hayden! Nice work on the custom bags and extra ballast.
Anyone else have an issue where their amplitude bar bottoms out intermittently? For instance we will be in the top third then it will drop to the absolute bottom which affects the plate position and the wave suffers. I saw the wake9 vid and writeup. It sounds like I might need to have the dealer check it out but wanted to check here as well.
@TXSurf4 are your shutting down the boat or turning off the battery when this happens to get it back to normal? Its weird because it will bottom out but then after a bit go back up.
