Does anyone have a picture of the enzo bags in the boat. I'm trying to figure out how much storage im going to lose.
Sent from my VS996 using Tapatalk
Its a great way to go. I like the flat plates better that pop bags. But i do have a couple of those also to move around easy. Go to some of the steal plants in your area and see if they have some scrape that will lay in your lokers.
I got a new setup for my 18 Craz. Bow and Port ballast 100%, Starboard 93%, Middle plate 25%, Starboard plate 45.
The wave is not as pretty but at 45 it has a ton of push to keep me 230lbs and 6' 1" going! Only thing I have extra is 400 lbs lead in rear and 100lbs lead in Bow.
Could go to about 20 feet back at the end of the rope and could still recover with this. Also had 5 passengers so that helped out a bit too. Would shift the heaviest passenger to rear surf side.
I will try that out. I was running about 4000lbs of ballast, with the middle plate at 14% and the surf plate at 55 with the speed around 11.2 and the wave was really tall but did not have a ton of push.
Here is a picture of the custom Mojo bags in a Mojo, I’m not sure if the Craz has the same size bench seat. They are 1270’s and give you a bit of room for storage.
https://uploads.tapatalk-cdn.com/201...3db719b4d5.jpg
https://uploads.tapatalk-cdn.com/201...55c2218c6f.jpg
