The heater install is next. any tips or suggestions would be great!!!
I'm planning on putting the heater blower/exchanger unit basically under the driver's seat.
In the obv I had a 4 vent system Two ppl outs in the walk way. One pullout behind the drivers seat and a fixed vent under the helm . I mounted everything under the helm on the back side of the sub hump . Also put two shutoff valves at the engine tap
The oem xlv heater only has two and no foot warmer for the driver . Boohoo
So I got a package of fittings from Wakemakers yesterday. So I made the hose adapter for the starboard drain pump. I measured and tried to get it nice and centered on where the bag's port will be.
https://lh4.googleusercontent.com/-m...225_185537.jpg
The back side of the starboard side drain pump:
https://lh5.googleusercontent.com/-B...225_185551.jpg
And the Port side pump. I'm hoping this will be on the mark for priming...
https://lh4.googleusercontent.com/-6...225_185623.jpg
Engine side of the Port drain pump.
https://lh4.googleusercontent.com/-X...225_185600.jpg
doesn't look centered to me, are you sure you measured correctly ?
Read the rules... No whipping anything out on the forum. Serious consequences for that sort of behavior.
^^^^ I can see why your a moderator. Nothing gets past you.
"Read the rules... No whipping anything out on the forum. Serious consequences for that sort of behavior. "
There always has been and there still is.... one moderator who has the power over the other moderators to whip it out.
What a turn this thread has taken!
http://youtu.be/EYlDbv7MqE8
I need that as a ringtone.
