Prop Shaft Alignment Yearly Maintenance Item
Quote:
Originally Posted by
yotaismygame
I loosened all 4 which made a gap. You're saying the two flanges should be able to completely separate? This was not happening for me. If I applied pressure with my left and measured with my right there was no changes. So it sounds like they are stuck together? I had a big gap all the way around even when applying pressure.
Spin the shaft from the prop end to free the coupler.
I also found the trick to closing the gap was to push the shaft in from the prop side. I could get it close on the coupler side but was able to close the gap by forcing the shaft toward the v-drive from the prop.
