2021 Mojo trailer 15's or 18's??
ok, so ordering a new mojo - do I want 15's or 18's on my trailer?
I had 15"s (or whatever the smaller size was) on my 2018 - and now looking at a 2021 - I selected 18's.. but want to know pros and cons?
I hear that that smaller ones actually hold more weight (which, I will potentially be trailering with lead).. so that's a plus..
the downside is I just didn't like how it looked on the max (they looked too small for the boat)... so I ordered 18's but understand that apparently they aren't as good in terms of the weight they hold? How big of a difference are we talking about?
Am I making a big mistake going 18's?
any difference in the trailer "ride"?
thanks!!
Quote:
Originally Posted by
Dank
Thanks guys!!! So a 2021 mojo - 4800 plus 850 lbs (5650) of lead sitting on 18's is a no go?
Our max was 4500 + 850 (5,350).. and had 15's
Are we close to a theoretical maximum here.. or am I being a drama queen? (King?)
Or, if I went with 300 lbs less in lead (500) - which I was maybe planning on... (same weight) ... would it be ok?
Same handling characteristics would you say? As far as bounce / rear sag of truck?
Of course I would never trailer with lead *asking for a friend.....
Speaking tire ratings only.....4 Nitto 420s (Boatmate tire of choice) 255/55/R18 XL will carry 9084# maximum.
There is a nexen n’fera option 255/45/18 that drops to a 7716# rating that I would not recommend.
4 trailer king 225/75/15 D will carry 10,196# maximum.
You are well under that with 5650# boat and 1500# trailer.
Just to add trailer height data.
255/55/18 tire is 29” tall
225/75/15 tire is 28.3” tall
Technically you would only raise trailer height 1/2 of 0.7”= 0.35”
My only issue with the trailer king 15’s are they are a Chinese tire, so take that for what it’s worth.
Guppydriver
This isn't related to load or weight, but I imagine a larger tire also gives you more clearance between the prop guard and ground. I'm thinking about upgrading to 20's just to have the additional 2.5 inches of clearance. I'm worried I won't even be able to navigate the slight incline to get my boat on my driveway. My trailer is coming with 15's, but it's not a boatmate...it's one called Metalcraft out of SLC. I hope it doesn't suck.
Rim size has nothing to do with clearance, it’s the tire height.
A low profile 20” tire could be shorter overall
Tire height dictates overall changes in height or clearance
Keep in mind, higher trailer height equals deeper you need to back into ramp.
Last thing I want at my ramps is a taller trailer
sandm
you get 15's on your new sa?
Hell No!!!! 18’s all day.
I am ok with 1” higher, just saying 20’s with an appropriate side wall aspect ratio is raising it too high
I have never had a boat that goes under an 8’ door. Do any new ones fit?
I can’t see any of the new SC boats clearing. But maybe I am wrong! No way a Mojo goes.
My Max barely goes under a 9’ door.
I STAND CORRECTED. [emoji1365][emoji1365]
(Get the 18s if weight capacity is your only concern).
Dank
We have a 48" outdoor storage that we pay for each month.. :( in fact, In the 3 years I owned the max, I never once put the tower down!
Depending what lake I go to, if it was far I would tower down to keep the bugs off coming home at night.
I do know one thing for sure, moving lead in/out of a boat is a pain in the arse.
