Ballast bag filling
I have a 2003 Outback LSV. The center ballast bag in the ski locker has started filling itself when the boat is under way. The 2 rear sacks work as normal. I have had to start turning off the manual valve in the engine compartment to stop it from happening, which means I have to open it to fill anything. It is a real pain. Any ideas? Thanks.
Ballast Bag Filling Idea
Posted elsewhere on this forum is a solution I tried and worked. Small debris can get caught in the manifold valve that will have it stick open. Cleaning out the valve -rinsing out the pieces - fixed it. BB
Check the Valve
Agree, probalby the valve
Happend to me:
See this post.
It was the selenoid (black cap), just unscrew it and replace the spring. Good luck!
If you have the sprinkler system, look for the little black lever at the base of the solenoid. Make sure that it is in the same position as the other two. If that little lever is in the wrong position, it opens the diaphragm inside the valve.
