what do you think a good board size is for a kid that is 5,4 and 115 pounds
erqwer
l
I would recommend a board somewhere between 124 and 130. A bigger board will give you a little more pop off the wake because there's more surface area, but you'll spin faster with a little smaller board. You probably don't need to worry a whole lot about those details, it makes a difference but not so much as the rocker, hull, channels, and the company that makes it.
I would recommend a board somewhere between 124 and 130. A bigger board will give you a little more pop off the wake because there's more surface area, but you'll spin faster with a little smaller board. You probably don't need to worry a whole lot about those details; it makes a difference but not so much as the rocker, hull, channels, and the company that makes it.
hey go with anything from about a 124 to a 133ish. should be good
A 133 would make it real easy for them to learn on.hell of a lot more stable and builds confidence with the youngins.
