What's the easiest way to get to the Oil Pressure Switch/Sensor on the engine? Pretty sure it came unplugged and do not want to take the entire engine compartment apart. Is it on the port side, starboard side, back, etc. Thanks.
Port aft bottom of the motor above the oil filter, it will have a single light blue wire going to it. Brian Raymond
Thanks for the reply. I think I have a broken wire somewhere near the engine that goes to the sensor. I have continuity to the heat sink located at the front of the engine. However, I can't get continuity after that. My oil pressure gauge is the only thing not functioning properly. I wouldn't think the heat sink would partially fail, shouldn't other things be malfunctioning if it were bad? Any ideas? Thanks
