Perfect Pass Digital Pro
My '04 Mobius LSV has Perfect Pass Digital Pro. I have some buddies that are pretty hard core skiers, and the PP has a "slalom" mode. When I change to Slalom and set a speed of 30-33MPH the boat never gets above about 28MPH. The speedo seems to read accurate, and PP maintains a perfect speed in wakeboard mode, so I can't figure out what's going on with slalom. Any ideas?
- Mobius Richard
i have heard what to do, i have even got instruction from PP. but i forgot how to do it.
i have found it easiest for me to just go to RPM mode and set the RPM for the speed i want to go. i think PP uses RPM anyway for slalom.
i am sure some one with better memory and more tech skills will answer.
I believe that you have to calibrate the slalom mode for each speed. You can contact PP and they will help you.
Yes as mentioned above you need to calibrate all the different speeds you want in slalom mode. I believe starting at about 22,24 mph through to 36 mph and if you want to get odd numbers you have to cheat the numbers . If you have the instructions , follow them from start to finish asuming your speedo is correct or use a gps to calibrate these.Not too hard takes about 5,10 minutes . If you don't have the instructions you can go on PP website or email for directions.
Thanks for the pointers, I'll give it a whirl calibrating it once I'm in the water for the season!
Yeah it can be frusturating, but once it's set it is sooo sweet. They don't call it the marriage saver for nothing :)
Marriage Saver
Damn straight, my wife doesn't try to hide when I want to ski anymore.
