Amp and Subwoofer Installation
I own a 2003 Mobius. I ordered it with the standard Kenwood stereo. I am going to use the same stereo and add a multi-channel amp to push the 6 speakers and a 2 channel amp to push a sub.
Does anyone have any suggestions on how and where to mount the amps and the sub? I want them to be as hidden and out of the way as possible.
Thanks,
Mike
Replying to Topic 'Amp and Subwoofer Installation'
I finally got around to doing my install this past weekend. Kent and Carol, your suggestion for using the cutting board worked out great. I purchased the largest one I could find, and my two amps fit with a little room to spare. I removed the wrap around seat back from the passenger's side of the bow. I used some flat head machine screws with large washers, and mounted the amp board to the back of that bow seat from inside the storage area. I put the sub in the area between the kick panel on the driver's side and the bow seat on that side. So far it sounds great. I should receive my tower speakers tomorrow. I look forward to hearing it after I have installed those. Thanks for the suggestions.
Later,
Mike
