Also you should find a zirk fitting on the rudder
On The some 2000 model boats you cannot get to this fitting with out removing every from the rear storage area :? . In my case (2000 mobius) this included trim panels floor of compartmant and both ballest tanks takes About an hour. :idea: how ever I solved this problem by going to the local hydraulic store and having a hose made with the same thred as the zirk fitting ( be sure to tell them what you are using it for) . the hose was long enough to reach the motor box area . Then reassemble rear storage area takes about another hour. But now rase motor box grese and go!
