Surf tabs won’t wake up ( pun intended!)
I have a 2016 Craz. Every now and then the surf tabs will not set. For instance, surfing port side I have the tabs set at 70% Starboard, 0% port. I flip the switch to surf port and the tabs read something crazy like 25% port, 10% starboard. If I continually flip the switch port, starboard, port, or shut the boat off then on again it will occasionally set the tabs correctly. Is this a computer problem? Does anyone else have this problem and is there a fix? Wake plate does a similar thing, will not respond to the control, then suddenly wakes up.
