DIY Surf Pipe/FAE - 05 XLV
Figured I'd post the results of my DIY fresh air exhaust project for my 2005 XLV that I based off of others posted here. I haven't gotten it on the water to test it yet but I'm happy with how it turned out so far. Open to modification suggestions if anyone has any.
I needed to make it easy to disconnect from the swim platform bracket because I have to remove the swim platform to fit it in my house garage when I do work on the boat. So I ended up using a bimini bracket off Amazon for the quick release pins and eye bolts coming off of the pipe hangers which worked out nicely.
https://i.imgur.com/udU6S1Z.jpeg
https://i.imgur.com/qKHTTu4.jpeg
https://i.imgur.com/J9gN6kV.jpeg
https://i.imgur.com/i94gEHt.jpeg
Here's links to what I used for this since some of the things were hard to track down:
Quick release bimini brackets
Eye bolts
Pipe hangers
Street 90 3" ABS
2 Way Cleanout T 3" ABS
1" Aluminum Angle
All stainless steel hardware, and did a crappy job spraying the ABS silver. For the downpipe I used a 5" long section of regular 3" ABS and put it in a bench vise with a heat gun to give it the more aerodynamic shape. I hope it reduced the cross section enough to not make a noticeable difference in the wake.
I wish I would have given myself a little extra room off of the wake plate because I can see its going to rub so I'm definitely going to pay close attention to that the first few times out on the water this year. Ultimately, I'm excited to see what all the hype is about getting out there on the surf wave without any fumes.
