Adhesive for decking - Why not construction adhesive?
My foam decking is really starting to peel off. I initially addressed this with the recommended 3M spray adhesive but will say that was only a marginal success. I prepped with acetone to get the old adhesive off. I found the spray application tough to work with in tight areas and did not get a lasting bond.
I am really close to pulling the trigger on using some construction adhesive. This loctite product seems like it would work and would be enormously easier to get the adhesive where you need it. Unless someone talks me out of it, might be heading to Lowes to give it a go.
https://www.loctiteproducts.com/en/p...nadhesive.html
