2017 Moomba Mojo does not turn over with key
2017 Moomba Mojo. Worked fine 2 weeks ago. I went to use this weekend and it would not turn over with key. Start solenoid does note even click. Checked batteries - good voltage. Lanyard is in. Unit is in neutral. I have rocked the throttle back and forth to make sure its not just out of adjustment as far as the neutral safety switch goes. With key in the run position, I can jumper the wire to the ignition side of start solenoid and it will turn over and start just fine. I have checked all fuses and circuit breakers that I can find. Put a volt meter on the ignition wire of the start solenoid - I do NOT get 12 volts when trying to start. Check ignition switch/key with ohm meter. When I turn it to start position I get continuity through the switch. I have jumped the 12v source going to key switch over to the ignition side and still do NOT get 12V at the start solenoid. So the problem lies somewhere in the wiring between the key switch and the start solenoid. I am certain it is something simple (neutral safety switch, fuse etc...) that I am just not finding. I have jumpered the lanyard switch with test leads and it still doesn't work - so I believe that to be ok. I am a farm equipment mechanic so I am plenty capable of diagnosing as long as I have the right information at my disposal.
1. Does anybody have access to or know where I can get a wiring diagram? I will gladly purchase for a reasonable price.
2. does anyone know where the neutral safety switch is? I would bypass for testing if I knew where it was.
3. Does anyone have any other suggestions or thoughts where there is a hidden fuse that I might be missing?
