Question on new (88 hrs) 2021 Moomba Craz overheated due to water valve being closed
Need advice please -
Got my boat delivered by the dealer yesterday. Last summer was my first summer so 88 hrs total. Ran perfect last year.
This year after driving it for 5-10 minutes I smelled something found the engine to be smoking. I immediately turned the engine off to inspect a bit more. I called the dealer.
When I turned the boat on again, the engine temp was now 210 and I got error messages - which I hadnt gotten yet when I smelled smoke prior.
I was advised to let the engine cool off then turn it on in small spurts to get back to the launch. I did this only a couple of times when a nice person towed me the rest of the way.
The dealer says that with a visual inspection that no real damage was done, except for an impeller that they had to replace. But all the other parts all look fine. I will get documentation that this occurred and that its their fault. They say that these engines are built to withstand far more than what happened yesterday (not that its ideal). They are lake testing before they bring it back too.
Any other inspections or diagnostics I should be doing or asking them to do to ensure I dont have some bigger damage that wont reveal itself until later?
The burning was your raw water impeller running dry.
210f is nothing, and you do have engine coolant circulating in the block, it was your heat exchanger system that was empty.
Unless you went up to 260+ I wouldn’t worry about it.
Check your oil and check for coolant in oil, if clean, you are fine.
Keep in mind this same engine is used in Ford Superduty trucks and operate at 210f all day under load.
Bummer your dealer f’d up, shit happens, it’s one of those things you never do twice.
