Supra Ballast System Bugging Out
2016 SA 400 - So this weekend we were surfing on my profile (bags almost 100% full) with everything working as it should. I then switched to one of the girls profiles (bags around 50%) and this is where it went haywire. It drained the rear left bag completely, drained the rear right bag down to 50% like the profile called for and then immediately filled it to 100%. As this was happening, a 'Manual Override Enabled' message popped up on the screen. None of the manual ballast switches were on or being used at the time. Manually drained the bags using the switches but the right rear bag would not drain. Turned the boat/battery switch off, let it sit for about 10 minutes and started it back up. I was able to now manually drain the right ballast but when you activate any of the profiles, the front and right rear bags will fill but the left rear does not. On the screen it shows that the right rear is filling, but no water is being pumped into the bag. I just had the pump impellers changed at the end of the season last year so I wouldn't think that would be my issue.
I spoke with my servicing dealer, the main tech has only seen this one other time and it was because of a bad battery connection. Also said to check fuses/breakers. I'm heading out to take another look at it after work but wanted to see if anyone else has ever encountered this?
Thanks,
Justin
