When to change out the prop?
New boat…. About 32 hours on her… hit a log… not hard just enough to slightly bend 2 blades right at the tip… just a few millimeters deep… and a couple cm across…. Pretty slight. Did not notice and shutter, vibrations, or anything unusual. Ok to run? Thoughts? Thanks in advance!
Quote:
Originally Posted by
Precious Roy
Another newb question…. If I bought the wakemakers prop…acme 2277 15x15.75…. It’s a half inch smaller and a little more low end. I like where the stock one has me right now. Will this one by any significant changes? Improvements? I guess just want to make sure I’m staying where I want to be….
Right now is the stock general use 15.5x16.5
If you like where you are at, why not stick with the prop you have?
The 15.5x15 will give you more low end, but raise your rpms
If you buy your new prop from nettles, you get a $50 coupon for repairing your prop.
