Sporadic high idle after warmup / 04 Outback DD
		I am experiencing high idle after running and engine is warmed up.  Seems to occur in association with shifting (but not always).
On startup, engine settles at 800 to 900 rpm… I live shallow so I idle out a long way before adding throttle above idle.
After pulling a skier or 2 idle will wander up to 1200 rpm.
I turn engine off and it typically resets. It is a not a consistent issue but I will not shift from neutral above 960 rpm. So I shut down and restart
Thoughts?
