Spring Cleaning
Hello,
I’m wondering what you all use to clean up the boat after winter storage. I have a 2018 Moomba Max and my interior didn’t get cleaned as well as it should have in the fall due to an early freeze. I use vinyl sauce on the seats. Looking for recommendations on what to use to scrub the soft step flooring and the interior gel coat areas. Also, is there any type of “soap” I should use to scrub the exterior (I use Hot Sauce after every use)?
Thanks!
I use this stuff for my EVA Flooring (Seadek, Gator etc) works well and smells good!
https://scwake.com/boat-juice/
I've used this on my flooring before and it works great, the only caveat is to make sure you rinse it off the floor thoroughly as it is slippery as all get out if you leave some of the residual spray behind then someone walks in with wet feet and busts their butt.
Hula RAD10 and RAD5 is the cleaner gatorstep recommends.
RAD10 is by far the best value, it’s concentrated RAD5 so you can make lots of RAD5.
