Looks like there are 5 drain points on my 2017 MOJO with the 440 Raptor.
I found one on the heat exchanger, another on the bottom of the v-drive,
And then I disconnected the cross over hose. Where are the other two?
Where is the impeller housing?
Center of the crankshaft pulley.
https://uploads.tapatalk-cdn.com/202...d43a076b67.jpg
Perfect thanks.
Can't find any brass fitting with the blue plug on the transmission line starboard side.?
Wouldn't the remaining plug be the plastic blue "wing-nut" type plug on the port back of the heat exchanger cylinder? Looking down from above oriented toward front of the boat, look for it protruding at about 7 to 8 o'clock off the HX.
