Does anyone have any good recommendations for an oil extractor? I have had two now and both were crap. They take forever to extract the oil regardless if the engine is warmed or not.
I like this one a lot.
Drains in a couple minutes.
OEMTOOLS 24397 9.5 Liter Oil Extractor, Oil, Transmission, Coolant Change Tool, Easy-to-Use Hand Pump, Extract Fluid Through Dipstick Tubes, No Mess https://www.amazon.com/dp/B01BW393E2..._JkxvFbSWJM9XK
i use a drill pump and it works awesome. you just need to get a connector to screw into the engine drain hose.
https://www.walmart.com/ip/Portable-...yABEgJwQvD_BwE
Appreciate it. I have the drill type from my old runabout. Never thought about getting an adapter and hooking that to the drain hose.
I like the pump type so I can change the trans and v drive fluid also.
Both good tips. Thank you.
I have this one as well and it works great on the Moomba, outboard on the toon, jet ski, mowers, etc.
