Peoples Final Venting Set Ups
2019 Max:
1200 rears
1000' midship
1000 Center
People or lead in Bow
In one of the threads people have done a ton of different set-up for venting the midship with rear bags. The thread sort of ended with nobody really saying what worked out the best after their set up and then using it. So.....I am trying to find out what was the ideal set up, so I don't have to bleed air on bags and its put together one time correctly.
My thoughts were.
access two vents on midship bag with a T
Connect to overflow of rear bag after sensor with a T
Single line then goes to a back flow above the exit hull hole drain
Thoughts, or something better?
Thank you for your help!
D
