The corners of the compressed foam stuff (let me know if there is a technical name for this) on top of my swim platform are starting to peel off. What adhesives have you found that work well for this application?
The technical name is EVA foam.
If your boat is under warranty, your dealer should take care of it.
If it's an older model, clean off the old adhesive with mineral spirts and acetone. Once the surface is clean, you can apply 3M spray adhesive and put the piece back in place.
Thanks. I see 3M has a range of spray adhesives; 45, 77, 90, 74?
