Wanted to share in case this helps someone out in the future:
2018 Max with a 400
I got this code on first startup this year (on the hose) and returned again when I put it in the water, I tried running it at higher rpm under load to clean off the o2 but it still came back.
4238: Closed-loop gasoline bank2 high
https://uploads.tapatalk-cdn.com/202...7e03973ac6.jpg
I did some research and this points to the pre-catalytic converter oxygen sensor on the starboard side of the engine. In my research I found a lot of posts about exhaust leaks, cracked manifolds, y-pipe alignment, etc. Since the boat is already on the lift an hour or so from my house I went ahead and cross referenced the indmar part number and bought a o2 sensor from autozone for $75 (around 1/2 the price of most marine suppliers). Bosch 17321. I typically don’t like throwing parts at something before doing the proper diagnostics, if I had more time I would have switched the bank1 and bank2 sensor and seen if the problem followed that particular o2 sensor.
Anyway, I drove up today and put it in, no more code! Fingers crossed it stays that way, if not I’ll post back up.
