2015 Indmar Raptor 400
Mechanics Special. $5000 obo. Complete motor for sale. Engine pulled from my 2015 Moomba LSV at 139 hours Aug 2019. Boat was purchased from non-Moomba dealer with a known overheating problem with coolant loss July 2019. Engine would start and run great at idle but exhaust gases over pressurizing closed cooling system above 2500 RPM. Motor was pulled and long block recommend by ProWake Watersports. I had them replace with Indmar bobtail complete replacement as the Raptor 400. This damaged motor is available for inspection and includes long block, rotating assembly with heads. The following items believed to be in good running condition; exhaust manifolds, catalytic converters, closed cooling system with heat exchanger and water pump, intake with K&N filter, flex plate, flywheel, starter, ECM with wireing harness, various clamps and hoses. Call or text. 765-744-6310
