Where is the wake plate sending unit on Mobius LA 2003 ?
Hi,
My gauge start acting weird. Sometime it goes below the low mark (down plate) and stop at 3/4 of the high level (high plate). Or while boating the gauge needle move sometimes by itself without moving the wake plate
I check the yellow wire voltage at the gauge and when the issue happens voltage is from 1.5v(down) to 5.5v(up). When it works fine voltage is from 3v(down) to 7.5v(up). So I am assuming the actuator sending unit is faulty. The Mobius LS 2003 has two electrical actuators. Would someone knows if the sending unit is part of the port or starboard actuator ?
