2018 SL Dual ballast fill issue
I've been troubleshooting a problem with the ballast system on my 2018 SL450 for a while, and hope that someone on here can help me figure it out.
My SL has dual ballast pumps to each bag that split off a single through hull. I noticed my left ballast was filling much more slowly than my right. After some troubleshooting, I realized that the left pump was spinning, but not pulling water. It's bone dry, and gets very hot as you can imagine. I checked the impeller and it is (suprisingly) fine. As an experiment, I disconnected the pump that was pulling. With that pump disconnected, the other pump began to function again. One thing that I am thinking may be an issue is that the non-pulling pump is mounted about a foot or so higher than the other pump. But it has always been mounted this way, as is the right side pump. And I assume that all SL's are set up this way. My dealer hasn't seen the problem before, and between us we are basically out of ideas.
I appreciate your help, as always!
