https://uploads.tapatalk-cdn.com/201...e166adf253.jpg
I am wondering if I can replace my original Rule 2000 pump with this Rule 3700 GPH pump without having to do any rewiring. In other words, can I just use the existing wiring and simply connect it to the new pump. I have no experience with doing anything electrical and therefore am always skeptical about doing anything that would mean rewiring or changes to the electrical system. I was able to replace the old sprinkler valve manifold with a new pvc/motorized ball valve setup but that only required soldering the old deutsch connector to the wires on the ball valves and reconnecting.
https://uploads.tapatalk-cdn.com/201...33ef8bb589.jpg
While this has worked well, I was thinking about adding another Rule 2000 pump off of a T like Kane and Newty had done years ago in order to decrease fill times but I found this pump and thought it might work as well as the 2 pump setup shown below.
https://uploads.tapatalk-cdn.com/201...170478926d.jpg
If I was to do either of these, I would probably run new 1 hose to my rear bags in order to take advantage of the increased flow. By the way, my pvc manifold and ball valves are all 1. Any advise on this would be greatly appreciated.
