2 Attachment(s)
Rule 2000 Hi Flow ballast or livewell aerator pump
I have 3 of these available. Two in another listing and pump 3 here. They are all the same pump. These are Rule 2000 livewell pumps that were used as original equipment in the aerator ballast systems. I believe they are rated at 1200 GPH. They have been in a box for a couple years since I changed my ballast system over. The box fell a while back and two of the pumps suffered cracked housings. They were repaired and you can see the results in the photos. The pumps work; all were tested today. The cracks were not to the part of the pump that moves the water but to the plastic part that houses the motor. So, while I would be confident using them in the boat I would not use them as submerged "throw over the side" pumps unless you want to use a sealer around the housing first. The prices reflect working condition but with the above stipulations.
Pump 3 sustained a cracked housing that was repaired. $20 plus shipping
Attachment 28227
Attachment 28228
