Guys I’m having problem with my trim plate. Gauge is slow to rise/lower but the actual hydraulic arm will not raise or lower. I’ve check the fuse and it’s okay. Any tips? Thanks in advance. 2012 outback v
Your boat should have a single Lenco electric actuator. Earlier boats boats had dual Bennett hydraulic actuators.
If your gauge is changing then it sounds like the motor is running and turning the pot but the ball screw is stripped.
