I just went through my 20 hour service on my 2018 Craz. I used the crankcase hose to drain the engine oil, sucked out the v drive oil and pulled the drain plug, and sucked out the transmission oil. I understand that there could be some residual oil left in the individual units, but what I added back seemed low on all three. I am fairly confident I got all of the oil out of the engine and v drive. I only added 7 quarts back to the engine, but the book calls for 8. I do not remember the exact capacities on the trans and v drive, but I measured what I sucked out and it was quite a bit lower than the book indicates. Has any one else experienced this? I only added enough back so that the dip sticks are at their full mark. I was shocked the the engine was a full quart lower than the book states. I will say, my previous 2 boats seemed to be the same way. I just wanted to get other opinions and see if you have had the same experience. And yes, I checked all the fluids after the engine was run and was hot.
