How is skiers choice wiring up the kicker 800.5 amp to 6 in boat speakers. I know the 5th channel is dedicated sub. Are they using 2 2 ohm speakers for channels 1 and 2 and then 4 4 ohm speakers for channels 3 and 4?
https://uploads.tapatalk-cdn.com/201...c4903cdaf0.jpg
You can sort of see it in the bottom right. I think they bridge the cabin speakers and the bow are on a separate channel.
All are 4 ohm speakers. bow pair on 2 chnls, aft port side parallel on one chnl, aft STBD pair parallel on last chnl. Only logical configuration.
Hi...This harness is a harness for adding an aftermarket bluetooth but is perfect for teeing in a AMP. Just cut off the plugs that were supposed to go the the bluetooth which are speaker wires and connect the red and black power wires back together between the radio plugs and your good to go.
