What to do if you get a dead battery?
So let's say you have a dual battery setup and you are running your boat on battery 1 for the day. You pull up somewhere, run the radio and your battery dies. Do you switch to battery 2 and start, switch to both batteries and start? If you start on battery 2, once you are started is it OK to switch to dual while the boat is running?
And speaking of battery switches, has anyone run into the following issue: You have your ballast switches switched to empty and you forget to flip them off, you then turn the battery switch to off. When I turn on the battery switch on and check the ballast screen it shows all ballast at about 70% full. I've used my manual external pump to fill up and then empty using the boat pumps but it takes a while. I've tried shortening the ballast timers, and then running them but that never seems to work.
