2004 LSV 3 switch bladder fill/empty controls electrical hookup to fuse block.
So, my kids mainly used this boat. It's time to sell and I'm trying to get everything working. Couldn't figure out why the bladders wouldn't fill. Put new ball valve, new solenoids, new sprinkler valves, checked the pump, and then found all 6 wires disconnected from the fuse block. Most likely from someone's feet under the dash. I tried to trace the color coded wires back to the 3 switches, left, right, front, and match them up with the fuse block left, right, front, but still not right. Each bag has 2 fuses,a 25amp fuse and center 10amp, left and right 3amp. Any ideas to find an electrical schematic for this hookup? Boat is 2004 Outback LSV with original factory setup.
