Clarification on wiring remote turn-on signal
So, my ongoing install consists of Exile 30.2 and Javelin amps as well as the ZLD2. I'm keeping my factory Fusion HU. Exile makes a point in their ZLD install videos about not getting power for the EQ from under the helm. The kit comes with a 3-wire power, ground, remote turn pair included in a long run to reach over to the port side amp rack location.
I understand that the HU power and ground and EQ power and ground should be kept separate back to the fuse distribution block at the amp rack. But, is there a need to take the remote turn on signal back as well? In other words, do I split the remote wire out of the HU for a short run into ZLD and then a long run that is further split into 2 wires for the 2 amps at the rack location? Or, do I keep the HU remote intact as one wire to the amp rack and then split it into 3: one for each amp and one long one back over to the ZLD?
Thanks in advance.
