As the title says...last winters winterization didn't go well. My question is...go back stock or is there another option for mor hp and low end torque for surfing
09 LSV indmar 325
09 LSV indmar 325
I suggest one of these for moar powa!
http://m.chevrolet.com/performance/c...l#.WEx1PcuIbqA
Would a stock gm vortec (car/truck) engine work?
Yes that's what they are. You just put brass freeze plugs in them. If I was really looking for more realistic hp I would upgrade the heads, you could have a sweet little motor if you want to play with it. But a stock bottom end will be plenty.
Don't bother upgrading, not worth the $$$, just upgrade the prop. I probably run more ballast then you and no issues. Acme 1433 baby..
Been a while but I think it's just a rv cam.
You know some cracked blocks can be repaired.
boats certainly are not like cars in that they don't have the same aftermarket support to facilitate upgrades. I would not want to take the chance upgrading the block and hoping the ecu can figure out what you have done. if it was my boat, I'd follow parrot and rebuild to factory specs with a different prop if you need it.
good luck either way....
