Originally Posted by
trayson
The old amp will have 4 pairs of speaker wires going to it. the new amp will have an 1/2 side and a 3/4 side. Connect both of the existing left positive and Left negative to the Channel 1 positive on the new amp. Do the same with the right side to channel 2. That will have all 4 of your cabin speakers powered by one side of the new amp. Run the new wires from the bow speakers to the 3 and 4 side of the new amp.
Then you'll want to set up the gains (input sensitivity) for this, crank up your head unit to around 80% of max then turn up the amp gain until the speakers start to distort, then back them off. You'll also want to balance the gain between the bow and cabins so the volume of the bow relative to the cabins sound balanced.
Set the crossover (filter mode) switch on the new amp to high pass (HP) for both 1/2 and 3/4 sides. turn the dial probably around 100 or so as a starting point. that will keep the lowest frequencies from your cabins and bow speakers.
I assume you only have 1 pair of RCA inputs to your existing amp. if so, then set the swtich on the new amp to "sum" the preouts.
your amp has a remote level control. it allows you to control the level of the amp with a spin of the dial. usually it's used to control the level of the sub seperately from the rest of your system. Since you're using the amp for in boat speakers, you probably don't even need to hook up the remote. But if you really wanted to, I guess you could use it as a way to fade out the bow speakers or something like that.
