OK, for almost everybody we have reached at least mid-season. We will be out till late October but try to get out by March or April. I thought it might make sense to offer up some mid season checks that you do to avoid missing time on the water as the season dwindles down.
Some things are obvious and you should be checking more frequently:
OIL, Trans Fluid, V-drive fluid, wakeplate fluid reservoir, trailer brake fluid, trailer tire pressure, hub grease
But what other things to you check or should you have your eye on. Please post your helpful suggestions below.
I would add:
Drive shaft coupler bolts, engine alignment, winch strap, and fire extinguisher.
Your thoughts???
