Outback V Tower Bolt at Base
Hello, all. First post. 2014 Moomba Outback V purchased in June. I love it. I noticed my bolt on the Star side was poking about half way out toward the boat. It has a cross screw pattern. I tried to screw it in but it won't budge. Banged with a hammer....no movement. Any suggestions? Dealer not handy. Thanks for your help.
Re: Outback V Tower Bolt at Base
Quote:
Originally Posted by
mcdye
cke66edy,
The bolt should be flush with tower. Get some assistance and loosen the tower lowering knob to take some pressure off the bolt on the front of the tower base and try to screw it in some more.
North Woods Mobius,
I have only seen the EZ lift on the port side. Might want to check to see if the spring has popped off the mount point. The cable on the starboard side is the stop cable for lowering the tower.
It may also help to have the assistant stand under the front of the tower and lightly lift up to take pressure off the bolt.
