Has anyone used plasti-dip on wakeboard racks? If so, how did it gold up?
2013 Outback V
2013 Outback V
You might want to check on getting them vinyl dipped like the factory ones. Look up vinyl coatings on the internet. I think the vinyl will be stronger and thicker.
I would love the idea of the vinyl but I'm guessing that is a bit more pricey than a $6 can of plastidip...
The racks have a pretty beefy rubber insert that takes most of the abuse and I was looking to just use the plastidip to color the racks black to match the tower. Of course the rest of the rack gets bumped and scratched when moving boards around so I was mostly wondering if the plastidip would stand up to those bumps and scratches.
Has anyone successfully put the rubber insert back in after it comes out? Any advice?
I can get it back in. It just won't stay there.
I've used super glue with some effectiveness but it tends to need reapplication over time. You might be able to use epoxy, but I've never wanted a permanent solution where I couldn't get the insert out if I needed to.
try some hightac trim adhesive
