08' Outback Gravity II Ballast Issue
I recently purchased my 2008 Outback V with the Gravity III ballast system. At the time I tested the boat I filled the ballast to confirm everything worked. In doing so I found out the rear right ballast empty pump doesn't activate when the switch is turned on. Obviously I purchased the boat regardless...
Having done a decent search on this forum and Owner's Manual I found it could be the following concerns:
- Fuse Blown for ballast pump
- Breaker on Switch Board tripped
- Pump Fried (seems fairly common)
I looked at the pump and found that the emptying nozzle where the hose attaches (on way to exit the hull) was cracked - So I am replacing that tomorrow regardless.
HOWEVER - When I looked for the Fuse Bank for the ballast system I couldn't find it. I found the regular fuses for all other circuits mounted under the dash no problem - All clearly labeled.
Am I wrong in expecting to find a separate fuse bank for the ballast????!?!?
I'm expecting 7 total fuses for the ballast: 1 Fill Pump, 3 Valves, 3 Empty Pumps
Can someone help me with where this would be? I'm pretty mechanically sound (won't take me longer than 30min to install the new pump tomorrow), however I'm starting to feel like an idiot on this one...if somebody has a picture of where it is located I would really appreciate it!
